Hello, I'm new on here and have been reading up on this problem but have not found a
solution.
I have a 9n with a 12 volt conversion and Pertronics electronic ignition. The
conversions are new. I had no spark and my wiring was cracking so I figured I would
upgrade. Problem is it won't run after I let off the start switch, it immediately shuts
off. I have run the red wire from the Pertronics module straight to the positive post
and the coil wire straight to the positive post. Front mount distributor. I installed
a solenoid and connected the starter through that. 1 wire from start position on the
solenoid to the positive terminal and it fires up just to shut down when I remove the
starting wire. Any ideas?
solution.
