Trying to get my 3 point to lift higher that the balls on the lift arms at 23 1/2" off the ground. I hear they're supposed to go up something like 34".
This is concerning the half moon cradle that the lift arm lever rides in. I found out that if I remove the outer piece from it so I can move the lift arm higher than the cradle, the arms will go up higher.
I'm wonder what keeps that lift arm lever cradle tight and how do I move it counter clockwise so my lift arm lever will go up higher?
The only thing I see is the nut and spring that keeps the friction disc tight. If I loosen that, will the lift lever cage be able to move?
