SLWagner73
So, all of you esteemed gentlemen, I have recently purchased a 2N for a fair price, I thought.
When I purchased it, it ran really rough, so I twiddled with the carb some, and then it ran great.
So, I ran out and purchased a brush hog (which was the whole reason for buying it in the first place) and after running a few laps with it, it started to overheat.
No big deal, figured I'd flush the system, put in fresh coolant, and I'd be good to go.
Ha.
And doing this, and running a few more laps, it overheated again, this time flooding out the distributor. So I opened it, dried it out, got it to run so I could get it back to the house.
Since then, I have replaced the radiator, the water pump, hoses, and while I had the hood off, I also replaced the sediment bowl.
Now, when I start it up, as I increase the throttle, it backfires out the exhaust, and when I put a load on it, it backfires and looses all its power.
I have checked the firing order, made sure that was right, I have turned in and out all of the screws on the carb (per the recommendations of several of the post), and now I am just lost?
I would say to make a long story short, but it's way too late for that!
Thanks for any help.
Scott
Ha.
Scott
