golden jubilee
i have a golden jubilee and when i have a implement attached and raised it will slowly lower then jerk back up suddenly can anyone tell me what my problem is
thanks
Are you saying that at idle the lift drops and then raises?
That's leakdown and regeneration.
Post back more details.
(quoted from post at 02:41:12 05/20/16) Are you saying that at idle the lift drops and then raises?
yes that is was is happening how do i fix it
(quoted from post at 22:41:24 05/19/16)
Find and repair the hydraulic leak. First place to look would be the hydraulic lift cylinder on the underside of the hydraulic lift top cover.
TOH
Lift cover kit with the big gasket and orings is about 15$, that and a 20$ i&t fo-19 you should be on your way
(quoted from post at 16:48:07 05/20/16) Lift cover kit with the big gasket and orings is about 15$, that and a 20$ i&t fo-19 you should be on your way
i will try this thanks for all the info
Ram cylinder O ring can be leaking. Pressure relief valve can be leaking. The gaskets between the ram cylinder and lift cover can be leaking.
On the early NAAs the unloading valve had no O ring and that caused the lift to correct from a slight leak around the unloading valve piston.
There was a recall but not all of them got replaced.
Zane
i don,t know what you mean 20$ i&t fo-19
Repair manual for your Jubilee. Your local farm store should have one, or you can get off of Amazon. Our host they also sell them.
(quoted from post at 07:06:08 05/21/16)
http://www.yesterdaystractors.com/FO19_6461.htm
I took the FO-30 to work and read it everyday on breaks . When it was time to do a procedure I was already familiar with the procedure and terms / part names . Then if you have a question you can be more specific instead of just general , which will save a few diagnostic steps and get your problem solve correctly .
(quoted from post at 13:06:08 05/21/16)
i will get one and see if i can fix my problem thanks
