http://www.pats3pointhitchsystem.com/
Well, I purchased this system for my 8N and it looks like it would work all right. The problem is that you can't use stabilizer bars with this thing. The pins are too short to get stabilizer bars on them.
I even called before buying and asked him if stabilizers could be used with his quick hitch and he told me "yes" all you have to do is turn the pin around. But that does no good, there is still not enough room to get a stabilizer bar on it. Besides, then the hole for his spreader bar which sets the distance between the quick hitches at the correct distance to meet the pins in the implement for easy hook up are on the wrong side.
If he would have just made a longer pin for this thing there would have been no problem. I'd even have paid for a longer pin as an added part but as is you can't run stabilizer bars with this quick hitch. I'm a little disappointed with it.
