Hi again all,
I have a (probably) '48 8N with front distributor, which was converted before it got to me to 12V and a Pertronix system.
It's been running fine, but I'm using it a lot for mowing, and the plugs are the same ones in it when I got it - 437's, which is what was recommended here as well. I figured I should get a new set and freshen them up, since I don't know how long these have been in.
What I'm wondering about it is the gap. I know with a standard points ignition, it's .025. Question is, do I still want .025 with the electronic ignition, or do I want a bigger gap? I have no instructions for the Pertronix at all. I'm going to try and search for that as well, but figured I'd ask here, since I'm sure a lot of these tractors are running this ignition.
As a follow up, it's running great right now, so should I leave well enough alone for the time being, or is it worth swapping the points out just because?
I also notice some sediment in the bottom of the glass bowl, which I know is why it's there, but how often do I need to clean that out? And is there a gasket I'll need to replace when I do it, or can I just pop it off and put it back on?
Thanks, guys.
Thanks, guys.
