ad's 2N won't spin over with the starter--New battery checks 6 volts-says he cleaned battery cable ends real good before connecting to new battery--only connection he has not removed and cleaned is the ground(braided cable--will do that tomorrow morning when I go to see if I can get it going..He decided to replace the starter cable so in doing so he has cleaned and made sure the cable connection at the starter is good..I'm beginning to think that the starter drive may be hung in the flywheel gear or broken connection inside the starter-Oh and he decided to replace the starter switch today too..What am I missing..Going to loosen the starter and wiggle it around to try to free the drive in case it is stuck and will ckean the mating surfaces where the starter bolts up...any other thoughts? Thanks
