Ford 8n knew style swinging draw install
I purchased a used swinging drawbar assembly from a 601 . the old style draw bar bracket underneath my 8n tractor is still there four studs holding it on. when I remove old bracket will I use existing studs or is there another set of holes under bracket . the were four bolts with the used knew style swinging draw .
(quoted from post at 18:09:35 05/10/16) I purchased a used swinging drawbar assembly from a 601 . the old style draw bar bracket underneath my 8n tractor is still there four studs holding it on. when I remove old bracket will I use existing studs or is there another set of holes under bracket . the were four bolts with the used knew style swinging draw .
Same holes and AFAIK you can use the studs if you wish.
TOH
(quoted from post at 18:28:46 05/10/16)
TOH
I re-used the studs on mine. Fit fine. They're a nice setup.
BTW, the studs came out of mine when I tried to take the nuts off.
No oil leaked out though so I'm assuming they are blind holes.
If that's the case I would not want to use too long of a bolt.
Good point Royce. Here is a picture of the inside of the rear housing.
