position control not working after rebuild
buddaone
New User
Ok the tractor is a monster it has an 8n engine 9n transmission and a cpl 2n parts. I did not know this until after it was broke all the way down. Now its back together and most of the problems I ran into have been sorted out but trying to get this 3-point to work is killing me. It worked before but now it seems as if the lever is binding, it springs up past half way then no resistance the rest of the way up. The pto works and spins there are no leaks that I can find, I've tried bleeding the pump it was good, the arms do not move at all. What would be causing this? and if you have pictures or diagrams that would be helpful
(quoted from post at 17:04:52 05/10/16) whatever it may be called the 3-point is not working can anybody help
emove the round side cover & verify that horseshoe arms are still connected to the tee on the control valve.
Welcome,
You may want to work the touch lever friction disk
located behind the lever by loosening the center nut
on the touch lever.
FO-4 manual is good help for pictorials and
procedures.
JMOR gave a great pic to show the internal linkage.
Looking there will tell where binding is occurring.
I assume you have dealt with the hydraulic linkage before and don't know if you rebuilt the pump itself or what else was done.
Regards,
Greg
Thx for the help guys I do believe it was just like that pic last time I did it and linkage looked good but i'll drain her and get pics of it later. For the rebuild everything on the tractor was broken down, cleaned, and rebuilt; engine, tranny, hydraulics, hubs, brakes, everything. this 3-point is the last thing to get figured out so I can break everything in and it's driving me crazy
