9N conversion to 12 V
rattler99
New User
Hey Guys, I've read a wealth of info from yall but i have an issue. i purchased a 6 to 12 v conversion kit and let it sit for a year or two before installing it. When I did, the coil was cracked. Can someone give me the correct NAPA # for the 12V square front mount coil?? thx
rattler99
The only NAPA number I have for a front coil is IC670 and that's supposedly for 6v.
You're probably going to need to order one here or from nnalert's.
While it is easier to use a 12 v coil, you can measure the resistance of a 6v coil and add the appropriate resistor in the circuit. (tip # 30)
75 Tips
Thanx Bruce. The numbers that I have are 9N12024-12V and 12VOLTCOIL but they don't cross match to NAPA. There has to be a 12 volt coil number.
rattler99
(quoted from post at 11:33:12 05/05/16) Thanx Bruce. The numbers that I have are 9N12024-12V and 12VOLTCOIL but they don't cross match to NAPA. There has to be a 12 volt coil number.
rattler99
That doesn't mean that NAPA carries it. To get a 12 volt square coil from my NAPA here they ordered it from TISCO.
Rick
