thefishhunter
Long story short, I have found a couple of shredders available here that could easily be converted to "self powered"
If you were using it like one of those ATV pull behind mowers / disc / etc. If your strictly pulling from the drawbar; How big a load could an 8n pull, all day through an overgrown pasture?
I'm thinking if you had NO pto horsepower being pulled off the motor and were just using it to pull, how much could you pull all day in second gear or even third?
I would assume that there are guys on here who have pulled hay wagons / grain carts / etc. FULL around with an N? Thats gotta be 8-10 thousand pounds at a whack?
All this is assuming the following: the brakes are great, the engine is tuned up and in good knick, basically that the tractor is in great shape and ready to work.
