Sherman Combo
Ken(Ark)
I have pulled the motor on my 8n for a rebuild . I am going to pull the Sherman Combo and sell it . It works perfect but I seldom use the 8n since I bought the 3000 . The stock 4 speed will be all I need and I could use the money .
What areas should I look at to make sure it is in good shape , I don't want to sell a lemon unless any problems are disclosed and priced accordingly .
Thanks , Ken . bonnerdaleken @ yahoo.com
Did it shift smooth, not noise, popping
out of gear etc? They are a pretty
rugged and reliable unit
(quoted from post at 07:57:45 05/04/16) I have pulled the motor on my 8n for a rebuild . I am going to pull the Sherman Combo and sell it . It works perfect but I seldom use the 8n since I bought the 3000 . The stock 4 speed will be all I need and I could use the money .
John Smith has an excellent page on disassembling and inspecting Sherman transmissions. A lot of good information.
(quoted from post at 10:13:13 05/04/16) Did it shift smooth, not noise, popping
Never rumbled or popped out of gear . Low gear worked good when I pulled stuff and high gear worked good driving 1/2 mile down the paved road between driveways .
(quoted from post at 11:40:10 05/04/16)
I'm interested in seeing what you ask for it. Surely you could get $700 to $800 for it in useable shape?
(quoted from post at 14:00:55 05/04/16)
Thanks for the John Smith Tip . I have read his pages a lot . There is so much there I never knew that part was there .
It looks like a second generation with open shift rails . Every thing is good and usable but not perfect . I need to weight it for a freight quote before I list it on ebay , who takes a 10% cut . I might get more if I wanted to sit it out but I would like to get some bills paid . I have seen $750 - $900 on ebay .
Ken(Ark,What is the brass fitting on the top where one of the detent balls and springs are for the shift rails for?
(quoted from post at 16:05:00 05/04/16) Ken(Ark,What is the brass fitting on the top where one of the detent balls and springs are for the shift rails for?
At first I thought it was a vent but now I figure someone lost the cap and that was what fit at the time ? I was just looking at that and decided to take a brake before making something that would work and not have a hole in it .
You will need to crate it that's a job in its self... I have always had the material on hand it was just the time involved to cut and assy the plywood.... My guess crated up 65lbs are less....
