jctunnelrat
New User
Hello All,
I'm new here and not sure if I'm in the correct forum. But... I have a question about a Ford 9n (1946).
Problem: Won't start, sometimes, most every time. But, when it starts runs great, plenty of power.
History: Been fixing this tractor for over 40 years. Complete rebuild in '76 and again in '94. Was a 6 volt positive ground system and recently converted to a 12 volt positive ground system. Now the tractor won't start consistently...
Compression is a little low (80-90 psi average). Compression was in the 60's, did a leak down test and had some bad valve seats/lapped valves brought compression up. Cylinder walls not scored.
Carb has been rebuilt. (twice)
Distributor has been rebuilt. Has good blue spark at plugs (all the time, even when won't start, and fuel)
New distributer installed.
New wires, plugs, electrical wiring.
Weird thing is when I completely cover the carburetor intake with my hand it will pop (sometimes). I was thinking intake leak but I can't find one.
I'd appreciate any advise/suggestions.
Thanks, jim
Thanks, jim
