I have a 1940 9N 12volt ignition and have some issues with the rotor not fitting properly with the distributor cap. I have tried tapping the rotor and it still is a little too tall for the cap to close properly. SO, I pulled out my back-up distributor and after setting points and new rotor, I had not spark at the plug. I checked the points and realized the contacts were only contacting by 50% of the contact area. I replaced points once more and still no spark, That is when I checked the rotor gap to the cap, by looking through the small port on top of cap. There must have been a 16th inch gap, so now I am off to locate an old rotor from my past tune-ups. Is this gap with the rotor ok or should the gap be much closer? Seems to me that it should be much closer than it is. Also, is there somewhere I may purchase a proper fitting cap and rotor?
William
William
