I want to change out the brakes on my Ford 9N. There are two studs that protrude from the back side of the drum. One is about 1" long and the other about a half inch. Are either of these the adjustment to tighten the brakes and do I have to loosen either one to remove the drums?
Also, do I just remove the bolts on the back side of the drum to pull the drum? Is any type of puller necessary? Any tips on removing the drums so that I might service the brakes?
I could not find a good video on line to see the process.
