Mr. T. Minnesota
Forum,
Do I have a case? Last summer I went to a quick change Valvoline for an oil change. They put in the wrong oil 0-20 instead of 5-30. Knew there was problem when the oil
gauge seemed out of order. Checked around and a mechanic mentioned there is oil with a 0-20 viscosity. When changing the oil to 5-30 the oil gauge read as it should. Two
days ago the engine began to rattle. Brought it to a reputable mechanic and sounds like bad rod bearings. What would you do?? The engine has only 70,000 miles on it. Any and
all thoughts welcome.
Mr. T. Minnesota
Mr. T. Minnesota
