Can't get the NAA clutch to adjust right. Don't have enough pedal throw to disengage the clutch, adjusting it tighter looks the pedal on the linkages.
Re-split the tractor this afternoon to take another good look. Here's details:
Linkages and cross shafts are tight. No play.
Throw out bearing is almost at end of the input shaft at full pedal throw. Doesn't have room to move more, tells me fork, shaft and linkages are ok.
Release bearing sits about 1/2 inch from contact with pressure plate fingers. Seems like release fingers are really low inside housing. Had to compress quite a bit to install the pressure plate.
Clutch disk is installed the right direction.
Everything is new, I purchased a complete clutch kit. Part numbers for the 8N and the NAA are the same for A 9 inch clutch. They both show two slightly different numbers but the NH website doesn't specify the differences.
When I took it apart it had flat washers under the PP. I'd rather find the problem than goober a fix.
HELP!!! Anyone see anything I'm missing? Is it possible the flywheel has been machined too much? I can't find any specs on how thick it's supposed to be.
Another question.... Can the fingers be adjusted to set them out more?
Any ideas appreciated muchly. TIA.
Marlin
Marlin
