2n hydralics
mshatto
New User
my 2n had abig problem I picked up a plow went to plow garden lowered plow and the draft control didn't work properly lift arms went all the way down ran front plow point into ground andback of plow can up in air bent draft control plunger don't know what else is messed up inside what all do I need to replace on inside
(quoted from post at 10:12:57 04/22/16) my 2n had abig problem I picked up a plow went to plow garden lowered plow and the draft control didn't work properly lift arms went all the way down ran front plow point into ground andback of plow can up in air bent draft control plunger don't know what else is messed up inside what all do I need to replace on inside
nd the rocker that top link attached to remained un damaged?
(quoted from post at 12:17:57 04/22/16)
es it is intact it broke pivot pin and hydraulics do not work now
yes it is intact rocker pin broke the spring and all standind up in air hydraulics do not work at all
(quoted from post at 10:46:47 04/22/16) yes it is intact rocker pin broke the spring and all standind up in air hydraulics do not work at all
ou will need to remove top cover hydraulic assembly in order to inspect & determine the damaged items. You are not going to know from looking at the exterior. Sorry, no ordering parts in advance.
