K-n-L Country Farms
These look pretty mean...the ride might have been a little bumpy but I bet you didn't lose traction very often!
We came across these on craigslist while looking for front wheel weights for our 8N. Looks like these were for a 9n or 2n.
The ad says "Two steel wheels bolt alongside rubber tires and allow you to drive on the road. 48-inches high, 6 lug, 24 3/8-inch bolt circle."
and so wanted to ask if this is true because we couldn't see how adding steel cleats along side your rubber tires would allow you to drive on the road...would think that if it had these mount to the tractor first, then there would have been a rubber tire that mounted to it so the steel cleats didn't slip on or tear up the road.
