Greg (2N) TX
John,
I have removed the thicker shims one at a time
having one paper gasket and one thin shim
included.
I have eliminated the shaft end play by removing a
thicker shim.
Now when I remove one thin shim, the shaft seems
to be harder to turn.
Should I leave the thin shim in as long as no end
play exists?
Thank you,
Greg
included.
thicker shim.
play exists?
Thank you,
Greg
