clutch bolts
I have split my 9N to replace starter ring. removed old ring, ordered new ring. My question is :Should
the bolts holding pressure plate to fly wheel have lock washers? The ones I removed didn"t have washers.
Will it hurt to put lock washers on them? What do you think?
If you are shopping for lock washers, you might want to get them from a heavy equipment dealer or industrial supply house, rather than a hardware store or TSC-type farm store which may be buying overseas from the lowest bidder. A lockwasher is one of those interesting hardware applications where a cheap one may be worse than none at all.
You might want to replace the bolts. When I replaced the clutch on my 9n. The heads came off one or two of the bolts when I tighten them.
