Brassbandit
New User
Ok so here's where I'm at mostly thanks to all the info I found on this forum.
So i am having problems with my lift namely it won't go down. Pulled the inspection plate and there was a milkshake inside. I drained all the fluid dumped in 5 gallons of diesel and fired up the old girl to clean out the sludge. I noticed that the lift won't drop all the way even with just diesel in there. I can raise it all the way up and when I push the lever down it falls quickly half way then stops.
If I shut the tractor off and give it a few hours the implement will drop to the ground. . If I leave the position control lever all the way down and start the tractor the implement immediately raises about half way.
What the heck is going on.
I'm going to continue cleaning it out tomorrow but I don't want to put in new fluid if I can't get my darn implement to go all the way down or I'll just have to drain it again to try and fix it.
