Berghandler
I had recently redid my carb on my 1949 8N because I had gas running out when I choked too much and not starting good. Took carb. apart and soaked it in carb. cleaner overnight. Cleaned it out very good. Then put a rebuild kit into it. Now no gas problem and start's good but when I try to adjust idle and load/run adj. needles I have no noticeable difference in running of tractor. I do get plenty of black soot at the tail pipe so I think it's running rich, but when I try to adj. nothing really happens to performance while running??? Also have no increase/decrease in first 1/4 of throttle so an adj. of governor might be necessary but that's just a spring tension increase/decrease by bending more or less. Not sure why no adj. at carb. screws?
