foothills ryan
New User
8n ('54) starts and sounds fine in idle, responds well to throttle.
But once I drive it, and it needs some power, it starts to miss and backfires and totally sapped of power.
Problem started last spring while running with brush hog. I could run for maybe 20 minutes then it would start to backfire and lose power. If I stopped, let it cool, I could start it back up and have normal operation for another 10 minutes or so until it got hot again. Since then the problem is worse and it doesn't take long or much load for the sputtering to start.
Yesterday we replaced the plugs, that didn't help. We've tried adjusting carb to no avail. The distributor points seem fine, good spark there, these were replaced several years ago. The distributor coil has been mentioned as a potential problem. The governor? Worse?
Any suggestions, links, advice is much appreciated.
