9n brake adjuster
Nick167
Should both pads move out evenly the one with the red spring moves out with shoulder protruding the adjuster but the side with the green spring won't come out that far and doesn't move the same distance?
Nick,
Put the wheels on and make sure the brakes work to YOUR satisfaction.
Especially, the right brake while holding the clutch down with the left foot.
Lots of times some brake is better than nutt'N while pulling a hay wagon with full load of hay!
John,PA
The adjustor should move both shoes in or out. Make sure you have the wedges inserted correctly. Look in with a light to make sure the cam is
working properly
