Hi All, I've been working on Dad's 48 8N since October. Finally got the engine unstuck, and running, new tires, rewired, yada yada yada... Thanks for all the great posts that helped me along on that journey. The problem I have now, is that I found another 48-ish steering box Dad had squirreled away. When I pulled it out of his hidey - hole, I didn't notice the top tube was unbolted, and it came apart. Kind of a good thing though, as one of the bearings was munched, and needs replaced. In the FO-4 manual, it calls this bearing "Worm Bearings" the one in the bottom of the housing still appears fine, since it has plenty of gear oil in it's life time. The question I have, is, are the "Worm Bearings" the same as the upper, and lower thrust bearings, part # 8N3571 ? Sectors are good, and tight, and the ball nut is smooth, and free turning. Other than replacing the broken bearing, and a good cleaning, is there anything else I should replace while I have it apart? Thanks for the help!
