hello all
Bought a 61 SOS 871 this past fall. 3rd owner, ran great until i left the fuel line open over a few days.
Started her up, ran her across the farm and she stalled. I looked at the carb and it was pouring out gas from the bottom. Was able to get her into the garage with no issues.
Flash forward a few weeks and got a 7' blade for her to plow the driveway. She started up fine then stalled when I attached the blade. I realized when i did get her started again, it would slowly stall out but stay alive if i choked the carb.
I recently ordered a tune up kit and replaced plugs, points, condenser, sediment bowl and oil / filter. Im having the same issues as before.
I noticed the gas is leaking out of the bottom of the carb again (dribbling) and started adjusting the needles according to the manual. I can get her to run at lower rpms and it stalls. I can get her to run at higher rams and it stalls before a full minute.
would it be safe to say the float is stuck and is flooding the carb out? I'm thinking since I left the fuel line open it wreaked havoc on my carb and may be gummed up.
Thoughts?
Thoughts?
