53 jub clutch
jtc
replaced clutch pressure plate pilot and throw out and clutch hub and spring 9inch still no clutch did adjuctment would a 10inch do better 53 jub
Sure a 10 inch would be better than a 9 but if you still don't have a clutch now after replacing all that you did, going back in and putting it together right will get you an adequate clutch with the 9".
i took apart twice had a little clutch for awhile then none tranny was rebuild then new clutch wondering if bushing would help
Jtc,Check for a loose or cracked throw out bearing fork on the shaft or a cracked or loose clutch arm on the shaft.That will cause a no release clutch problem.As you stated adjusted and had some clutch for awhile then it went away.
