Looks to be a good deal if anybody is in the area *NOT MINE*
Big Trees
It's not mine and I don't know the seller. I don't know a whole bunch about tractors yet but I do know this looks like a good deal if it's in the condition he says it is. I'm not in the position for another tractor now but I figured maybe one of you might want to look at it.
http://dallas.craigslist.org/sdf/grd/5377600026.html
(quoted from post at 22:39:26 01/26/16) Why do my links I post not come up as clickable links?
if posting using Modern View, then you need to place "url" ahead of & behind your link by clicking on the url box then paste link then click on url box again. If posting using Classic View, then ask. It should look like this without the quote marks that I placed here (instead of leading & tailing brackets) so that computer won't see it as a url & you can see what you need to do.
"url]http://dallas.craigslist.org/sdf/grd/5377600026.html[/url"
(quoted from post at 20:24:47 01/26/16)
JMOR, thank you for explaining that to me. I will do that from now on. I appreciate that.
As JMOR said, you need the url tags.
They would look like this when you put them in.
Whether you click the button or type them. (faster for me to type them)
[code:1:6d5d51ccc0][url]http://dallas.craigslist.org/sdf/grd/5377600026.html[/url][/code:1:6d5d51ccc0]
Which will show up like this: http://dallas.craigslist.org/sdf/grd/5377600026.html
If you want to get "fancy" you can add an equals sign, move the first closing bracket and a label like this:
[code:1:6d5d51ccc0][url=http://dallas.craigslist.org/sdf/grd/5377600026.html]Ford 2000[/url][/code:1:6d5d51ccc0]
Which would show up like this: Ford 2000
Sometimes the links are really long so I use this method to make them shorter.
Classic view has boxes for you to put the url and label in separate,
but since I see you using the quote feature I'm assuming you're using modern view.
That is a bargain.
Engine parts for those 144ci diesels are
somewhat hard to find if you ever needed
them but they are available. My pal Kenny
had one rebuilt. Though I prefer the 3
cylinder Fords I always kinda wanted one of
those 601Ds.
The diesel would put their gas sisters to
shame when it came to fuel economy.
Smooooth power.
Thanks for the instructions on how to post clickable links guys, I appreciate that.
Ultradog MN - I thought that was a deal too. You know I don't know much about tractors but I paid more than $1200 for my N so I knew this had to be a good deal.
If I had the extra tractor money it'd already be sitting outside the house but since I don't I'm hoping somebody on here will take advantage of it.
a follow up on using the formatting tags, like URL.
disclaimer: i'm on modern view, i don't know what this looks like in classic, or whatever the other mode is called.
to tag text in a post, u can either manually type the tags, one at the start of the text u want tagged, and one at the end with the / in it, or u can use the easy way ;)
highlight the text u want tagged. u can do this with the mouse or keyboard - mouse, click and hold left button and drag across the text - keyboard, position the cursor at the start (or end) of the text u want tagged, hold down shift, and use the arrow keys. in the case of a link, highlight the entire url (the http:// and all), and then click the URL button up above the posting box, and the forum software will insert the tags for u. this works with all of the buttons in the row that ends with the URL button :)
(quoted from post at 00:25:48 01/27/16) As JMOR said, you need the url tags.
[code:1:37d25427af][url]http://dallas.craigslist.org/sdf/grd/5377600026.html[/url][/code:1:37d25427af]
[code:1:37d25427af][url=http://dallas.craigslist.org/sdf/grd/5377600026.html]Ford 2000[/url][/code:1:37d25427af]
In Classic View you can directly enter any HTML you want and I much prefer the increased power that gives you. IIRC at one time you had your choice of using BBCode or HTML when posting/replying from Modern View but that got turned off. I still occasionally use Classic View when I want to format a "fancy" HTML reply but it seems it doesn't play well when inter-mixed with other BBCODE posts. Probably why the option went away....
TOH
ps: if u mouse over the buttons, it will pop up a little description of what each does.
If the deal is right I'm not adverse to
traveling for it. I've made 2 trips to TX
from MN to fetch tractors - about 900 and
1000 miles respectively - each way.
You're a bit farther I know.
(quoted from post at 05:09:44 01/29/16) If the deal is right I'm not adverse to
Glen Rose Texas is a probably about 1.5 away from me, everything in Texas seems to be far away considering how large the area is. I looked up St. Paul to Glen Rose and it's a little over 1000 miles so not much further than your previous trips.
I hate that I'm as strapped right now for extra money because I'd love to add it to my collection but there will be another one that comes along when I'm ready to buy again. I see he updated his ad with some different pictures so it appears it's still available.
