liltwisty101
New User
I have a 1951 Ford 8n that I am replacing the leaking rear axle seals on as well as the rear hubs. I set the bearing load as described in the manual and began reassembling the parts. The right side went as planned an assembled as it should. I then assembled the left side. After tightening the left axle nut, the left rear axle would not turn, even with a cheater bar it was extremely hard to turn. After some investigation I noticed that the hub was touching the metal portion of the outer seal/retainer causing it to be extremely hard to turn. Does anyone know what could be causing this? Could it be that the seal is not centered correctly? It almost appears that the metal on the retainer that holds the outer seal has been bent inward causing a gap between the seal and the retainer on the inward side. Prior to tightening the left axle nut both axles turned as they should, one forward and one backward. Any help or thoughts would be greatly appreciated and thanks in advance. This has me puzzled and trying to figure out where I went wrong as I followed this detailed article, http://www.oldfordtractors.com/rearseal.htm ,to a t.
