corchel1942
Restored 1945 2N, 6 Volt system with cut out and 1 wire generator. I just had to replace my battery, it was leaking around the battery posts and stopped holding a charge in a very short time.
My question is about the charging system, and am wondering if it could be possible if the generator is over charging. What should the generator be putting into the battery while running, and when should the cut out shut it off?
I'm keeping the float charger off until I make sure the charging system on the tractor is working correctly.
Thanks
Corey
Thanks
Corey
