Well, I took everyone's advice and bought a distributor gasket kit. It came with a cork gasket for the distributor cap. The thing is, this gasket causes the distributor cap to not sit totally flush against the body. There is a recess in the cap that looks like maybe the gasket should fit into, but when I attempted to do that a section at a time when I got to the end there was too much gasket if that makes sense. (Like the diameter of the recess and the diameter of the gasket are different. I put it on as is and rtv'd on the outside between the cap and distributor base.
Will I have any problems?
