8n pressure
cxsr
New User
i trying to figure out the trouble with my lift....no leaks...lift stays up overnight....i made a tap and put on a gauge...lift seems weak..lifts scoop ok but wont lift brush hog....is 450 psi enough?
(quoted from post at 14:56:23 01/17/16) i trying to figure out the trouble with my lift....no leaks...lift stays up overnight....i made a tap and put on a gauge...lift seems weak..lifts scoop ok but wont lift brush hog....is 450 psi enough?
ressure is load dependent. Light weight=low pressure, heavy weight=high pressure. Chain the arms down to get full pressure reading of 1600 psi.
IF it stays up overnight, WITH A LOAD on it, then, probably eliminates most leak points. With no load, doesn't mean much. IF no leaks, then pump & overpressure valve are suspects.
im kinda dont have a clue what to do next....i would like your advice of what to do next....thanks for your help
(quoted from post at 15:45:51 01/17/16) im kinda dont have a clue what to do next....i would like your advice of what to do next....thanks for your help
was heavy on the word "if"......did it in fact hold up a LOAD overnight? Or just empty arms?
Earlier I said over pressure relief valve or pump. Over pressure valve is cheaper & easier to change, so I would try it first. Check for visual relief while arms chained & trying to lift & then change it if indicated early relief or simply go ahead and replace it.
IF a man could check the ability of the system to hold pressure while the pump was in a static mode... :idea:
cxsr I assume by shredder you mean a bush hog..
I raise it up shut the engine off then stand on the back of the hog and jump my fat arse up and down. If it falls down a little each time the pressure relief valve would be a good place to start...
I have for a short time fix a relief issue this way but the issue always returned in short order.
http://forums.yesterdaystractors.com/viewtopic.php?t=363452&highlight=relief
