CL Engine - Michigan
"aren't blocks the same on front and side mount engines"
Not exactly. The side mounts had the generator moved to the
left side, for example, and there are no holes in the front mount
block to mount that generator. When they moved the generator,
they also had to move the oil filler tube back to make room for it.
(quoted from post at 10:59:41 12/02/15)
(quoted from post at 22:32:02 11/30/15) I think I would have cleaned it up a bit.
Actually I applaud his honesty - no attempt to make it look better than it is....
TOH
I look at it as he was too lazy to clean it up a bit. But then that is just me. :D
I'm surprised how many people are
concerned that it's dirty, wouldn't
worry me the least, looks just as one
would look removed from a working
tractor. If it was clean with a fresh
paint job I would be nervous
