Looking for 8N tractor repair Tampa/Ocala area Florida
Tampa
New User
I have an 8N tractor that will not turn to the left. Does anyone know how I can get it fixed? It is located between Tampa and Ocala, FL.
Thanks.
Get a set of manuals (tip # 39 at the link)
Pull the hood off (tip # 12)
Remove the Pitman arms from the box (you will need to buy/rent/borrow a puller)
Remove the steering wheel (tip # 73)
Remove the box from the tractor. (4 bolts)
Take it apart & find the problem.(you will need to replace the seals in addition to whatever you find wrong w/ it)
These guys should be able to help you w/ used parts:
John Smith smith8NATatt.net
Rod Mondor fltractorATpeoplepc.com
Replace the AT in the address w/ @
Rod forest lake tractor 651 464 4628
75 Tips
There's a guy named Jim in Brandon that does tractor repairs and sells parts and could probably help you. I've linked it below, but in case it's deleted, you can go to Craigslist for Tampa and search Tractor Parts for $25.
CL Link
(quoted from post at 15:50:07 11/29/15) There's a guy named Jim in Brandon that does tractor repairs and sells parts and could probably help you. I've linked it below, but in case it's deleted, you can go to Craigslist for Tampa and search Tractor Parts for $25.
CL Link
Thanks!
