Was having two problems...still have one
1. Pressure plate stuck to flywheel
solved this one by driving the tractor out in my pasture where I had some open space, put it 3 gear (couldn't get it in 4th) opened the throttle wide open then stepped on both the clutch and the brakes(s). After about three 20' tire slides it broke loose. This obviously works better if you have good brakes.
2. Smoking out the exhaust (grey oily)
Dry compression 97, 100, 100,102
Wet compression 130 125 130 130
So why the smoke?
So why the smoke?
