9n interchangeable transmission to pinion shafts from jub...
jtamez3
New User
Hello, I have a 41 9n tractor that I am
rebuilding. I got the motor running and
then ran into another problem, it wouldn't
move! After some research, I found that
the transmission to pinion shaft has a
break. There is a jubilee model tractor
nearby that I can buy parts from. I believe
it's a 54. Will the shaft from the jubilee
fit my 9n?
(quoted from post at 21:41:52 11/24/15) Hello, I have a 41 9n tractor that I am
fit my 9n?
Parts book says they are different numbers. 9N-4605 for all N-series and NAA-4605A for the NAA.
TOH
If I remember correctly the NAA shaft is shorter than the 9n shaft.
I can check later cause I have both out but If it were me I would get the right one for the 9n. John smith is a good seller.
Kirk
