1940s Ford Tractor (Engine is an 8N, Gearbox 9N and Rear is 2N).
Converted to 12V
Tractor worked beautifully the last two years following an engine rebuild. I used it extensively this summer and fall. It sat in the garage for two weeks (the garage is heated and it never got below freezing).
It will not start.
The battery is new(ish) and fully charged. I have 12V at the battery and all the way to the starter when the key is turned on. There is no volts to the starter when the key is turned off. No clicking....nothing. The gearbox is in neutral. I cleaned (though they weren't corroded) all the connections from the battery (including the ground) all the way to the starter.
Any advice is most welcome. Thank you.
Converted to 12V
It will not start.
