What type of water to use !
yukon73
What type of water should I use to mix my antifreeze for my 1952 8N....Well water...bottle water...city water...distilled water...I have reverse osmosis well water or softened well water? I live in Michigan (cold) ??????
I have always used what ever was the handiest. I think bottled water would be overkill. Doubt if too many farmers used anything other than well water.
getting technical, distilled water is likely the best of your choices.
I've never used anything other than well water ( in florida ), and no issues.
I use only distilled water in cutting antifreeze and use it only in my batteries. I get it by the gallon at the grocery chain store.
While distilled water is probably technically the "best" choice, I'd venture to say that 99% of all the Ns have whatever water source was the closest in their radiators.
yukon73.......uh? yukon is in Alaska, isn't it??? You kenn already buy 50/50 green anti-freeze already mixed fer people like you. Good fer minus 35-deg. (-35*) Iff'n I remember my chemistry, reverse osmosis is essentially the same as distilled water ...ie... NO MINERALS. Go with that. CAUTION: iff'n you mix yer own anti-freeze, you need to add water pump lube. Wynn's was a brand name supplier. BIG TIP: check yer rear tires fer traction enhancing water weight. Shuld have calcium chloride (salt) as an anti-freeze. Taste it, its NOT poisonous. ........the amazed Dell
If your N is anything like mine - it has had everything in it from well water to something dipped out of a nearby stream. I know one of my tractors has had whatever was in the nearby stream put in once when I had a leak and needed to add after the leak was repaired (no well nearby, and certainly no distilled water). Any of the above would be fine in my opinion.
It won't matter as long as its clean. I would bet that most all the water available in Michigan in 1952 was well water.
I've used nothing but distilled water in cooling systems since reading lab retports while a design engineer at GM years ago.
Dean
Agree. My well water has a lot of calcium carbonate in it. Actually I buy the premixed stuff. But if not not premixed, I use distilled water.
I'm in Michigan too; Ionia County.
Cold isn't the issue with the type of water.
Contaminants and minerals/calcium are.
I have very hard well water so I use distilled water.
Either that or I buy it pre-mixed with distilled water.
Watch what brand you buy though, not all use distilled water.
RO water would work well too. I don't think I'd dump the salt
water from a water softener in their to cause even more rust.
As the others have said, these tractors have had everything in
them over the years and they live on. Question now is, how
can you treat it best with what's available.
Distilled water is cheap.
LOL--exactly what I was thinking..and have always done..Now if I buy that new Kubota I have been wanting forever I might boil the pond water to kill the tadpoles..might even strain them out
The only water that I would worry about using would be a surface water source. many municipal supplies have huge lake reservoirs. The water can be very acidic, and harmful to engines.
