thelonepatriot
New User
I have a later 8N (side mount distributor). When I lift an implement on the 3 point, in this case a 6 foot disc, it will not stay up while transporting it. The lift slowly bleeds down. My other worn out tractors, 2 Fords and a Ferguson will bleed off a little bit but will pump back up. This 8N does not pump back up unless I drop the lift lever all the way down and raise it again. The PTO is running all the time that the lift is bleeding down. This is a major pain when I am transporting, especially when I am on the road as I have to stop the tractor to re-raise the implement without damaging it or the road. I have never had one of these apart and would like a few suggestions as to what to look for and what parts to have on hand before I tear it apart. Since my shop is the all season kind with no roof, no walls, no heat, no shade tree, and has a dirt floor I am hoping this can be a one day repair. I do have several repair manuals, I & T and some Ford reprints.
Thanks
thelonepatriot
Thanks
thelonepatriot
