Governor Housing
elstone
New User
The governor housing on my 8N was leaking like crazy. Pulled it off and found it was severely warped and the gasket had been made up with about 1/4" silicon to try to make it work. I ordered the new housing below.
The race went into the new housing fine, just a little tight and a couple of taps to seat it home. When I went to install it on the tractor, looks like the bolt holes in the new housing are made for 3/8" bolt. Mine has a 7/16" bolt. And yep, I'm using the short bolt that came out.
Is it OK to just drill the housing out a little? Want to make sure I have the right part.
Thanks folks.
Governor Housing - Governor Housing includes needle bearing, Lip-type seal, bushing, and proofmeter drive cap with seal and nut. For 8N, 9N, 2N tractors built 1939 thru 1952. (Part No: 8N18085)
