I've wired quite a few of these alternator setups.
I normally wire them the same as JMOR's wiring diagrams show.
I have one here that is wired with the excite wire hooked
through the key switch to #1, normal, but then it is also
jumpered to #2 for the sense voltage.
There's no diode or light on this one (and it shuts off fine) so
I don't see a whole lot of difference electrically other than the
resistance of the key switch and wiring length, which are minor.
Still battery + to sense wire.
It charges fine and has for 5 or 6 years that I know of so I am
not planning on changing it unless you guys see a reason to do
so that I am missing.
