noveaufarmer
I am trying to get my '54 NAA working again. It started quickly as usual on Monday and I drove it out to the job site (about 5 minutes) to move some limbs. Just as I got there and began to work, the engine began running rough and started back firing. Then it died; I was able to get it started again but it ran poorly. I removed the distributor cap to find pitted points and a distributor cap with well worn contacts. I had some new points and a new distributor cap that I intended to install when I gotround to it so put them on. Now I have no spark at the points. I'm suspicious of the small copper connector running from the side of the dizzy to the points. Is it supposed to touch the side of the distributor housing? How is that supposed to be installed? Any other ideas on trouble shooting? Thanks!
