I have a 55 ford that is having a difficult time running all of a sudden. The tractor appears to have a miss at idle, applying the throttle has no effect, still misses then stalls out, thought it was gas but flow pretty good out of tank. I currently replaced the cap, rotor, plugs, points and wires. The tractor was running fine afterwards. This new formed issue came out of the blue, was thinking maybe coil. The way the tractor looks to be wired is battery, key, resister, coil, then distributor. Does anyone have any recommendations on what might cause this issue that i am experiencing?
Thank you
Ron
Thank you
Ron
