After replacing my clutch plate, when I try to start the tractor it turns over about a half turn and then stops. I pulled the tractor in half again and the engine rotates freely when I turn the flywheel by
hand, the prop shaft turns freely by hand and the starter works fine by it's self. I put the whole thing back together and it still will not rotate more than a half turn.
What should I look at??
