Brian Jasper co. Ia
I have a 52 8N that the left brake will come on by itself and drag. The shoes are new, axle seals are new, the axle bearings have the correct preload. The drums were resurfaced and I added a pedal return spring. I've set them tight and loose but the left side will still come on by itself driving forward. The only thing that helped a little bit is the added return spring to the pedal. At this point the only thing I can come up with is maybe the brake material's coefficient of friction isn't quite right for this application. What am I missing here?
