Hydraulic piston
I will try again
I think someone took a stock original piston and put a o-ring on it.. I pulled apart a '48 and had the same piston but all 3 grooves had the steel rings. Has a naa piston with a o-ring in it now.
(quoted from post at 17:10:23 10/03/15) That's what was in it. No steel rings, just an O ring. Perfect fit for the O ring.
Surface finish is way too rough for an o-ring. Since it is a used piston I am guessing that is corrosion????
TOH
If I get time tomorrow I will get the measurement of the o-ring grove are what its spose to be to use a o-ring and back up washer in that groove...
TOH knowes for sure I got the tip from John Smith on the modification and have done several myself...
(quoted from post at 21:49:47 10/03/15)
The archives are your friend. I have posted the specifications (lifted straight from the factory prints) a number of times
TOH.
Don't know how well it was working, engine was bad so I didn't try it. It appears to be a 3 ring piston that someone enlarged the last ring groove into a rubber seal groove. The corrosion looks worse in the picture than it really is because of the flash. I've got some rings and rubber seals around the shop, I think I am going to put both of them on and see how it works.
(quoted from post at 01:42:04 10/04/15) Don't know how well it was working, engine was bad so I didn't try it. It appears to be a 3 ring piston that someone enlarged the last ring groove into a rubber seal groove. The corrosion looks worse in the picture than it really is because of the flash. I've got some rings and rubber seals around the shop, I think I am going to put both of them on and see how it works.
Flash or not that surface is much rougher then an o-ring groove should be. Since I retired my time has become much more valuable ;-) andI hate doing jobs twice. Iif it were mine I'd spend the $23 a new NAA piston costs....
Just FYI here are the original Ford specifications:
[b:32a63da2b9][u:32a63da2b9]NAA-530B Hydraulic Piston[/u:32a63da2b9][/b:32a63da2b9][list:32a63da2b9][*:32a63da2b9]OD : 2.4985/2.4997 before phosphate coating[*:32a63da2b9]Phosphate thickness: .0001/.0003[*:32a63da2b9] Groove[list:32a63da2b9][*:32a63da2b9]Width: .311/.316[*:32a63da2b9]Diameter: 2.114/2.118[*:32a63da2b9]Corner radius: .030[*:32a63da2b9]Surface finish: [color=red:32a63da2b9][b:32a63da2b9]100Ra[/b:32a63da2b9][/color:32a63da2b9][/list:u:32a63da2b9][/list:u:32a63da2b9]
[b:32a63da2b9][u:32a63da2b9]NAA-533A O-Ring[/u:32a63da2b9][/b:32a63da2b9][list:32a63da2b9][*:32a63da2b9]Diameter: 2.090/2.110[*:32a63da2b9]Cross section: .205/.215[*:32a63da2b9]Max flash: .003 high, .005 wide[/list:u:32a63da2b9]
[b:32a63da2b9][u:32a63da2b9]NAA-473A Backup Washer[/u:32a63da2b9][/b:32a63da2b9][list:32a63da2b9][*:32a63da2b9]Outside diameter: 2.485/2.515[*:32a63da2b9] Width: .183/.198[*:32a63da2b9] Thickness: .084/.104[/list:u:32a63da2b9]
HTH,
TOH
