Rotor and Distributor cap for 9N 1952 Ferguson tractor
randam
New User
I am looking for a rotor and distributor cap for a 9N 1952 Ferguson tractor. The rotor is flat on the top. The distributor cap has four notches and one little half U circle on the bottom. It is a clip on cap which has screw on wires.
The distributor is side mounted, has overhead valves.
Rivet has broken off of rotor and taken chips out of the cap.
Does anyone know where I can find a new or used one??
Thanks
Pictures really would help a bit. Not a 9n since they have a flat head engine as did the 52 8n.
your post might make more sense to a Ferguson owner.
Randam,Just a guess you must have a TEA-20 or a TE-20or TO-20 and not a 9N Ford.Need to know what it is you can check on the Ferguson board.
http://www.yesterdaystractors.com/store/parts/pics/wm_B4789.jpg
http://www.yesterdaystractors.com/Ferguson-TEA20_Distributor-Cap_B4789.html
http://www.yesterdaystractors.com/Ferguson-TO20_Distributor-Cap-4-Cylinder_1750411M91.html
Check above site. Here ya go.
randam.........justta FYI......the Ferguson Tractor engine is same engine used Triumph TR-3 sports cars.......Dell
There are plenty of places you can probably find one on the interweb, but if you want it now you might try local farm stores or maybe even an auto parts store. I bought my cap/rotor/points and coil from local auto parts store but it was for a side mount 8N.
