Okay. So I was finishing torquing down my head bolts yesterday and bolt 17 snapped. I didn't have a bit of trouble with the others, just that one. Yesterday, I was so aggitated that I had to walk away from it. But now I am wondering if I should attempt to use an easy out to remove the broken bolt or if I should just bite the bullet and drill it out and re-tap the hole in the block.
Any suggestion?
Also, does anyone know the what size and grade bolts the 8n uses on the heads? It is a 51 8N, side mount.
Any suggestion?
