8n Oil Breather Tube.
dkirwin87
Hello All,
My 8n is one of those side mount distributor models that was effected by the oil breather/ fill tube baffle issue. I Have been noticing a slow drip of oil out of the filter element and it appears my tractor never got the redesigned tube. I am trying to resolve my oil leaks and this is an annoying one as it tends to make a small puddle right under the breather. Is there a source for the redesigned tube? or a clear way to identify them on the used market? Thanks again for your help.
(quoted from post at 14:44:58 09/24/15) Hello All,
ry this:
http://forums.yesterdaystractors.com/viewtopic.php?t=1222714
(quoted from post at 15:02:33 09/24/15) I had seen that but is there a part number for the later tube? Or can i use a 9n or 2n tube?
ou asked for a clear way to ID them & it looks like the linked post shows that, but as far as part numbers, I have no info.
These guys should be able to help you w/ used parts:
John Smith smith8NATatt.net
Rod Mondor fltractorATpeoplepc.com
Replace the AT in the address w/ @
Rod forest lake tractor 651 464 4628
75 Tips
